STM32L0 RTC_LSI (calibration) example appears not to work.
This is the firmware I'm using: STM32Cube_FW_L0_V1.11.0 I'm using the Nucleo-L073RZ board and example. The RTC_LSI example does not work. The LED goes blank after pressing the user button. The Readme says this indicates some kind of error. I can't post the code as its too long. What do I do? Can someone provide a fix or an explanation for why the example does not work? Thank you.
