STM32H743 FMC NOR hangs after repeated external resets
My STM32H743 application runs from internal Flash, with some code and data in external NOR via FMC. It runs stably for days without NOR issues, but after repeated external resets the board eventually becomes silent and will not recover with an MCU reset; power-cycling restores it. HAL_NOR_Init() has writes disabled, and captured pre-FMC pin levels were unchanged. What should I check to identify whether FMC/NOR initialization, access sequencing, or reset behavior causes the hang?
