Vineeth CN
Oct 16, 2020 6:56 AM UTC
STM32H743 - Ethernet with MicroChip PHY - KSZ8863RLL in RMII mode
Hello Everyone,
I am trying to establish Ethernet communication with STM32H743Bi controller in my custom board. Am using 3 port PHY from Microchip - KSZ8863RLL in RMII mode.
I am generating the code using STM32CubeMX with the LwIP Stack and FreeRTOS. Currently i cant even ping the board. I am using STM32CubeID.
In cubeMx i could select only LAN8742 as PHY. In BSP->Components folder i can see the LAN8742.c and .h files. I understand i need to replace the these files with corresponding KSZ8863RLL files.
Does anybody know how to configure. Please information's.
help me.
Please let me know if i need to provide any other
Thanks and Best Regards,
Vineeth
umtkyck
Aug 2, 2021 6:47 AM UTC
I am also working on the same concept, did you find a proper solution for different ethernet phy on stm32h7?
Regards,
Umit
Aug 7, 2023 9:42 AM UTC
Hi, I'm also working with STM32H7 MCU and trying to connect it with microchip LAN8670 PHY,
In my case I am connecting it to the PC using EVB-LAN8670-USB dongle (that looks like working)
Using the LwIP stack and static IPv4, I tested my code using integrated to the nucleo board ETH PHY and it works.
But using the LAN8670 face the same problem - no ping.
I assume i need somehow to apply the configuration code from here
https://www.microchip.com/en-us/product/lan8670#document-table
Did someone achieved the stable connection using any michorchip PHY ?
