MHana.1
Apr 30, 2024 7:09 PM UTC
STM32H743 as a client fails in handshake with server at Server Hello using LWIP, mbedTLS and FreeRTO
I'm using STM32H743 to send and receive REST API. I'm using FreeRTOS, LWIP and mbedTLS to communicate with server. I have the same application working WELL using STM32F765 with MCAL layer of course modified to STM32F7 but using H7 I can see this error "Unknown Record Type" when fetching input and reading input record. I tried solutions like optimizing cipherSuite but was not useful.
MHana.1
MHana.1Best answer
Nov 10, 2024 2:32 PM UTC
Resolved by updating ethernetif.c
MHana.1
MHana.1Author
May 1, 2024 2:10 PM UTC
Here is the log:
Setting IotClientHandle options...
Modify IotClientHandle Options Success. Try Connect
. Connecting to Server URL: port 443...
The SSL configuration is tls12 only.
Performing the SSL/TLS handshake...
=> handshake
=> flush output
<= flush output
client state: Ðä
=> flush output
<= flush output
client state: ´Ðä
=> write client hello
client×?g$þaéZY:2 ciphKÀsuite: 2400BF7C, Ùo633¨\{
adding EMPTY_RENEGOTIATION_INFO_SCSV
client hello, got 1 cipher suites
client hello, adding server name extension: X$¾U$Ðä
adding signature_algorithms extension
got signature scheme [2400BF94]
client hello, adding extended_master_secret extension
client hello, adding session ticket extension
client hello, total extension length: ?u
=> write handshake message
=> write record
output record: msgtype = ?, version = [?:?], msglen = ?u
<= write record
<= write handshake message
<= write client hello
=> flush output
message length: ?u, out_left: ?u
<= flush output
client state: <Ðä
=> parse server hello
=> read record
=> fetch input
in_left: ?u, nb_want: ?u
<= handshake
=> handshake
=> flush output
<= flush output
client state: <Ðä
=> read record
=> fetch input
<= fetch input
input record: msgtype = ?, version = [0x2400BF3C], msglen = ?u
=> fetch input
<= fetch input
handshake message: msglen = ?u, type = ?, hslen = ?u
<= read record
server hello, current time: ?u
server hello, session id len.: ?u
session has been resumed
server hello, chosen ciphersuite: 2400BFE4
server hello, compress alg.: 604028900
server hello, chosen ciphersuite: 9
server hello, total extension length: ?u
found renegotiation extension
found extended_master_secret extension
<= parse server hello
=> flush output
<= flush output
client state: ´Ðä
=> parse certificate
=> read record
=> fetch input
<= fetch input
input record: msgtype = ?, version = [0x2400BF54], msglen = ?u
=> fetch input
<= fetch input
<= read record
Use configuration-specific verification callback
Certificate verification flags clear
<= parse certificate
=> flush output
<= flush output
client state: 8Ðä
=> parse server key exchange
<= skip parse server key exchange
=> flush output
<= flush output
client state: ðÐä
=> parse certificate request
=> read record
=> fetch input
<= fetch input
input record: msgtype = ?, version = [0x2400BE14], msglen = ?u
=> fetch input
<= fetch input
<= read record
got D certificate request
<= parse certificate request
=> flush output
<= flush output
client state: xÐä
=> parse server hello done
=> read record
reuse previously read message
<= read record
<= parse server hello done
=> flush output
<= flush output
client state: ÔÐä
=> write certificate
<= skip write certificate
=> flush output
<= flush output
client state: XÐä
=> write client key exchange
=> write record
=> flush output
<= flush output
<= write record
<= write client key exchange
=> flush output
<= flush output
client state: Ðä
=> write certificate verify
=> derive keys
=> calc verify sha256
<= calc verify
ciphersuite = 9
eylen: ?, minlen: ?, ivlen: ?, maclen: ?
<= derive keys
<= skip write certificate verify
=> flush output
<= flush output
client state: ¨Ðä
=> write change cipher spec
=> write record
=> flush output
<= flush output
<= write record
<= write change cipher spec
=> flush output
<= flush output
client state: Ðä
=> write finished
=> calc finished tls sha256
<= calc finished
switching to new transform spec for outbound data
=> write record
=> encrypt buf
before encrypt: msglen = ?u, including 0 bytes of padding
<= encrypt buf
=> flush output
<= flush output
<= write record
<= write finished
=> flush output
<= flush output
client state: Ðä
=> parse change cipher spec
=> read record
=> fetch input
<= handshake
=> handshake
=> flush output
<= flush output
client state: Ðä
=> read record
=> fetch input
<= handshake
=> handshake
=> flush output
<= flush output
client state: Ðä
=> read record
=> fetch input
<= handshake
=> handshake
=> flush output
<= flush output
client state: Ðä
=> read record
=> fetch input
<= fetch input
input record: msgtype = ?, version = [0x2400BF6C], msglen = ?u
=> fetch input
<= fetch input
<= read record
switching to new transform spec for inbound data
<= parse change cipher spec
=> flush output
<= flush output
client state: ÐÐä
=> parse finished
<= calc finished
=> read record
=> fetch input
<= fetch input
input record: msgtype = ?, version = [0x2400BF5C], msglen = ?u
=> fetch input
<= fetch input
=> decrypt buf
<= decrypt buf
<= read record
<= parse finished
=> flush output
<= flush output
client state: 0Ðä
handshake: done
=> flush output
<= flush output
client state: ÐÐä
=> handshake wrapup
=> handshake wrapup: final free
<= handshake wrapup: final free
<= handshake wrapup
<= handshake
ok
[ Protocol is TLSv1.2 ]
[ Ciphersuite is TLS-RSA-WITH-AES-128-GCM-SHA256 ]
[ Record expansion is 29 ]
. Verifying peer X.509 certificate...Connection phase complete.
Connected to server.
Data Buffer Before Send:
/token.oauth2?client_id=&client_secret=&grant_type=&scope=api HTTP/1.1
Host:
Content-Type: application/json
Content-Length: 0
post buffer (?u):
=> write
=> write record
=> encrypt buf
<= encrypt buf
=> flush output
<= flush output
<= write record
<= write
post net_sock_send: len=265
=> read
=> read record
=> fetch input
<= fetch input
input record: msgtype = ?, version = [0x2400C184], msglen = ?u
=> fetch input
<= fetch input
=> decrypt buf
<= decrypt buf
<= read record
<= read
net_sock_recv() rc = 360
=> read
=> read record
=> fetch input
<= fetch input
unknown record type ?
failed
! mbedtls_ssl_read returned -0x7200
net_sock_recv() rc = -1
http_recv() ConnectionError
Receive Connection..........FAILED!, ERROR -0x1
=> write close notify
=> send alert message
send alert level=? message=?
=> write record
=> encrypt buf
<= encrypt buf
=> flush output
<= flush output
<= write record
<= send alert message
<= write close notify
Freeing the mbedtls context anyway.
=> free
<= free
Closing and Destorying Connection, Result 0
MHana.1
MHana.1AuthorBest answer
mƎALLEm
Nov 11, 2024 10:02 AM UTC
Hello @MHana.1 ,
Is that possible to share what modification(s) you applied to ethernetif.c ?
