May 7, 2026 08:19 UTC
STM32H7/LWIP: IP Ping Error
Hi Community,
I'm a new Developer/ for ST Microcontrollers, Now Im currently using STM32H723ZGT6 (NUCLEO - 144). Im currently working on ethernet (LWIP), the ping is not working for this code that i have generated . I have seen some youtube channels but I cant rectify and make the ping, I have tried all the possible things like , flash linker script , enabling ICache , Dcache , using MPU(Memory Protection Unit), change them to static ip for both board and my PC and So on . I have tried but I dont know whether my code or my implementation is correct or not . Can anybody help me with this ?..
I have attached the file thats my code and how project. pls have a look into that.
Thank You.
mƎALLEm
May 7, 2026 08:44 UTC
Hello @Gokul_Sarvanakumar_60 and welcome to the ST community,
How to create a project for STM32H7 with Ethernet and LwIP stack working
May 7, 2026 11:31 UTC
Thank You for the reply still its not working, I cant identify the issue.
mƎALLEm
May 7, 2026 13:20 UTC
I'm almost sure you didn't follow the exact steps described in the knowledge base article.
Pavel A.
May 7, 2026 14:23 UTC
May 11, 2026 03:34 UTC
can we do IP config without Free RTos , if possible pls share me a precofigured code , so that i can compare with my code and understand  the error
May 8, 2026 04:21 UTC
yes these pre- configured are perfectly working.  but my own code is not working
May 11, 2026 06:17 UTC
@Pavel A. @mƎALLEm ,
I'll followed all the steps in the article . Now if possible review and provide the Alterate solution . so that ican compare and do the coding
Pavel A.
May 11, 2026 07:31 UTC
Hi @Gokul_Sarvanakumar_60
Here you can find preconfigured LwIP examples without RTOS: LwIP_TCP_Echo_Server, LwIP_UDP_Echo_Server
https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Projects/NUCLEO-H723ZG/Applications/LwIP
Also you may want to try Mongoose  https://mongoose.ws/wizard/#/
May 11, 2026 09:06 UTC
Hi @Pavel A.  , Thanks for your continuous  support and reply, yet  still i cant figure it out . all the preconfigured is running but i cant remake it on my own , if possible , I am ready to have a one on one conversation with you. anything through G meet or Team or even im ready to give my personal mobile number. my personal mail : gokulsha990@gmail.com
