STM32H573 Secure Manager: PSA Crypto Issues with TLS 1.3
Hello everyone,
I am trying to use TLS 1.3 with Mbed TLS on an STM32H573 through the Secure Manager’s Global PSA API.
At the moment, I am seeing the following errors:
psa_sign_hash() / psa_sign_message()
→ PSA_ERROR_NOT_PERMITTED
psa_generate_key() / psa_import_key()
→ PSA_ERROR_GENERIC_ERRORThe persistent ECC keys are provisioned with the required signing permissions, and both the Secure Manager and the non-secure application start correctly.
Some TLS 1.3 HKDF operations had to be implemented locally because the PSA Crypto API version in use is 1.0 and does not provide separate HKDF-Extract and HKDF-Expand algorithms.
My questions are:
- Are persistent ECC keys supported with
psa_sign_hash()through the Global PSA API? - Does the Secure Manager support volatile keys with
psa_generate_key()andpsa_import_key()? - Are additional permissions or a Secure Module required?
- Is there a support matrix or an official TLS 1.3 example for this setup?
- Does anyone have experience with Secure Manager and MbedTLS 1.3, or with configuring Secure Manager for TLS 1.3?
Thank you!
