Nov 23, 2023 11:59 AM UTC
stm32F767 SDRAM bootloader
I am currently trying to implement a bootloader that runs from the internal flash and performs the following functions:
1. copy application binary file to the SDRAM ( 0xC0000000)
2. Jump to main application.
So far I can copy the binary from the external flash to the SDRAM but when I try to jump to the SDRAM I am getting a hard fault error.
I have configured the MPU region to enable all access but I get the same result.
There are 2 points that are for me not clear:
- Does the SDRAM application have to be compiled with a specific linker configuration?
- Do I have to de initialize all the peripherals?
    Joe WILLIAMS
    Nov 28, 2023 6:38 PM UTC
    Hi CFranco
    Your inquiry has been processed via the Online Support Center.  We appreciate you taking the time to reach out to us.
    Kind Regards
    Joe WILLIAMS
    STMicro Support
