embvis
Jan 24, 2017 10:07 AM UTC
stm32f767 and UART DMA IT (interrupts)
Posted on January 24, 2017 at 11:07
How to use UART in DMA mode with interrupts IT.
I use the next code to transmit, and it works perfect.
HAL_DMA_Start_IT(&hdma_usart3_tx, (uint32_t)msg, (uint32_t)&huart3.Instance->TDR, strlen(msg));
huart3.Instance->CR3 |= USART_CR3_DMAT; // DMAT: DMA enable transmitter
But receive Rx doesnt work
HAL_DMA_Start_IT(&hdma_usart3_rx, (uint32_t)&huart3.Instance->RDR, (uint32_t)uRxBuff, 8);
huart3.Instance->CR3 |= USART_CR3_DMAR; // DMA enable receiver
DMA config:
/* Peripheral DMA init*/
hdma_usart3_rx.Instance = DMA1_Stream1;
hdma_usart3_rx.Init.Channel = DMA_CHANNEL_4;
hdma_usart3_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_usart3_rx.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_usart3_rx.Init.MemInc = DMA_MINC_ENABLE;
hdma_usart3_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
hdma_usart3_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
hdma_usart3_rx.Init.Mode = DMA_NORMAL;
hdma_usart3_rx.Init.Priority = DMA_PRIORITY_LOW;
hdma_usart3_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
hdma_usart3_rx.XferCpltCallback = &DMAReceiveComplete;
if (HAL_DMA_Init(&hdma_usart3_rx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(huart,hdmarx,hdma_usart3_rx);
hdma_usart3_tx.Instance = DMA1_Stream3;
hdma_usart3_tx.Init.Channel = DMA_CHANNEL_4;
hdma_usart3_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
hdma_usart3_tx.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_usart3_tx.Init.MemInc = DMA_MINC_ENABLE;
hdma_usart3_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
hdma_usart3_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
hdma_usart3_tx.Init.Mode = DMA_NORMAL;
hdma_usart3_tx.Init.Priority = DMA_PRIORITY_LOW;
hdma_usart3_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
hdma_usart3_tx.XferCpltCallback = &DMATransferComplete;
if (HAL_DMA_Init(&hdma_usart3_tx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(huart,hdmatx,hdma_usart3_tx);
#stm32f7 #hal_uart_transmit_dma #interrupt #dma #stm32f767
Oliver Beirne
Jan 24, 2017 10:14 AM UTC
Posted on January 24, 2017 at 11:14
Hello
I have moved your post to the
https://community.st.com/community/stm32-community/stm32-forum?sr=search&searchId=0445f8b7-528c-419e-8c3d-1fe561f8525f&searchIndex=0
‌ where someone should be able to assist you.
Oli
Jan 25, 2017 10:52 AM UTC
Posted on January 25, 2017 at 11:52
Hello
Zarzycki.Mikolaj.002
I suggest that you run and test the UARTexample withinthe last version of STM32CubeF7 firmware package relevant to the STM32 device you are using. This will help you on UARTconfiguration and identify
the root cause of reception error.
You may review the UART example using DMA under this path: STM32Cube_FW_F7_V1.6.0\Projects\STM32F769I_EVAL\Examples\UART
Imen
embvis
embvisAuthor
Jan 25, 2017 11:58 AM UTC
Posted on January 25, 2017 at 11:58
But there is no information how to use IT (interrupt) mode of DMA. I have problem with it, no with other modes
I want use
HAL_DMA_Start_IT, not HAL_UART_Receive_DMA or  HAL_UART_Transmit_DMA.
Thank you
Mikołaj
Jan 26, 2017 10:43 AM UTC
Posted on January 26, 2017 at 10:43
Hi Mikolaj Z,
Refer to the
http://www.st.com/content/ccc/resource/technical/document/user_manual/45/27/9c/32/76/57/48/b9/DM00189702.pdf/files/DM00189702.pdf/jcr:content/translations/en.DM00189702.pdf
 'Description of STM32F7xx HAL drivers', this will help you with more information about using DMA on
interrupt mode.
Imen
