STM32F7 STM32F769 DFU configuration
Iam trying to use software DFU bootloader trigger from STM32 application (BOOT1 and BOOT2 are untouchable). Application use USB-FS (service/CDC) and USB-HS (data/CDC), but trigger will be send via existing USB-FS (CDC). USB-FS use PA11 and PA12 and will be used as the same interface for DFU. HSE use 25MHz (ST recommend 8M). Is it possible to use DFU triggered from software in upper configuration?
Mikolaj
