Senior
Sep 9, 2023 12:27 PM UTC
STM32F429ZI FATFS issue
I'm trying to use FatFS with both USB HOST MSC class and SDIO.
FatFS always tries to access the SD card whatever the drive number used in f_mount.
May be I'm wrong with the path I use to access the devices : "0" for SD card, "1" for USB.
Any help will be welcome.
zeboss49Best answer
Senior
Sep 9, 2023 1:44 PM UTC
Issue is solved.
I stepped into f_mount and found thaht the path was missing the ":" i.e. path must be "0:" or "1:" not bjust "0" or "1".
Thanks for the answer :)
Issamos
Sep 9, 2023 1:11 PM UTC
Hello @zeboss49
Can you add your code to understand more about your request.
Best regards.
II
zeboss49AuthorBest answer
Senior
Issue is solved.
