STM32F429 FMC No action
- 3 replies
- 406 views
Hello
I want the STM32 to transmit data to the FPGA via the FMC. However, when I use the manufacturer's example and modify the return line in the FPGA, the LCD displays the modified value from the STM32 instead of the expected return line value. What configuration setting in the FMC_Test project am I overlooking that is preventing the correct value from appearing on the LCD?
