Feb 11, 2025 8:38 AM UTC
STM32F415RGT6 USB HS in Internal DMA mode.
I am trying to use the internal DMA mode on USB_HS as a device mode. Can I get relevant USBD_LL_x api's which support it. And a sample example code which uses this DMA bus for configurations.
Thanks,
Srinath
Feb 13, 2025 4:10 PM UTC
Hi @S_Srinath
Are you using custom board with external PHY? AFAIK, we don't provide an example for High-speed operations in DMA mode on F4. You may check this article How to correctly setup your application to use USB... - STMicroelectronics Community.
