hukhongcongtu26111993
[STM32F407] CS43L22 problem!
  • December 16, 2017
  • 7 replies
  • 2063 views
Posted on December 16, 2017 at 02:40
Hello!
I am working with CS43L22 on STM32F407VG Discovery Board.
I use Audio_playback_and_record example to play .wav file.
If i use headphone, I can get good sound. But If I use speaker I get small sound.
Is that normal?
#audio #cs43l22
Posted on December 18, 2017 at 15:14
Hello
quoc.anh
This can be caused by software configuration issue.
Weneed few more details on your software configuration about used speaker output.
Best Regards
Imen
waclawek.jan
Posted on December 18, 2017 at 15:34
Aren't the speaker outputs of CS43L22 unconnected on the STM32F407VG Discovery Board?
Posted on December 19, 2017 at 05:29
Yes. I was consider STM32F407 Discovery schematic and CS43L22 Datasheet. You are right! Thanks you for your confirmation.
