AbdurrahmanOnat
Apr 21, 2023 2:12 PM UTC
STM32F401CDU6 USB CAN'T RECOGNIZE
I have an STM32F401CDU6 blackpill board and I have a USB not recognize code 43 error when activate dfu mode. It's don't do it 3 months ago
AbdurrahmanOnat
AbdurrahmanOnatBest answer
Apr 25, 2023 7:46 PM UTC
USB is problematic way with this board (blackpill). If you can buy a ST-LINK programmer (I buy a ST-LINK V2) and programming with this way. No button combination, no problem.
I am close this post now. Thanks to everyone.
Apr 24, 2023 8:05 AM UTC
Hello @AbdurrahmanOnat​;
Let me first welcome you to the Community :)
Maybe the problem is with your cable, so try a different cable, and make sure that the connections are OK.
Check if the USB_OTG_FS_DP and USB_OTG_FS_DM wires are swapped.
In the USBD_config.h, check you have the correct out-report buffer size (USBD_CUSTOMHID_OUTREPORT_BUF_SIZE)
 Please keep me informed about your progress on this issue.
Imen
AbdurrahmanOnat
Apr 24, 2023 6:49 PM UTC
Thank you for your friendly welcome.
I tried with a different cable but the result is the same. USB_OTG_FS_DP and USB_OTG_FS_DM wires are not swapped. Because board is worked on 3 monts ago. I can't do any programming process because Windows can not recognize the USB.
Thanks for your attention.
Abdurrahman
AbdurrahmanOnat
AbdurrahmanOnatAuthorBest answer
