STM32F4 USB reg NZLSOHSK bit question
Posted on February 12, 2013 at 18:27
Hi you there!
Got stuck while programming a USB vendor specific device on STM32F4 MCU. The device is intended to be self-powered with custom usb driver.During initial programming (core and device init. settings) I don't know what actually to do with the NZLSOHSK bit. What is it responsible for? If we turn to , it says that non-zero length data is a DATA from the host and should be read by the application. So what to do with this bit? Should I keep it ''0'' or where am I wrong?Thanks,Peter. #usb #stm32f4
