STM32F4 PA7 used by Ethernet and MEMS? Solution PTP?
I have following Problem. Iam try to get Data from the MEMS and send it via Ethernet to another Controller. My issue is, that the Pin PA7 is used for the SPI Mosi and the Carrier Sense Data Valid by the Ethernet (RMII).
Now iam trying to receive Data without the PIN PA7 (Carrier Sense Data Valid). How I Can get my Data without using this Pin? Is PTP a possible solution for this?
