STM32F4 Discovery – Main Application Stops Running After Changing RDP Level from 0 to 1
Hello ST Community,
I am facing an issue with my STM32F4 Discovery board after changing the Readout Protection (RDP) level from Level 0 to Level 1 using STM32CubeProgrammer.
Issue Description
Initially, my application was working properly with RDP Level 0. I then changed the RDP level from Level 0 to Level 1 using STM32CubeProgrammer.
After this change, my main application stopped running. Nothing happens after resetting or even performing a complete power cycle of the board.
Steps Performed
- Programmed my application successfully with RDP Level 0.
- Verified that the application was running correctly.
- Changed the RDP level from Level 0 to Level 1 using STM32CubeProgrammer.
- Reset the board.
- Also tried disconnecting and reconnecting the power.
However, the application does not start executing anymore.
