arilink
Sep 30, 2021 8:02 AM UTC
STM32F105 DFU BootLoader does not work
I successfully used USB DFU on STM32H7, and I want to perform the same operation on STM32F105. I learned from the manual that the system BootLoader address is 0x1FFFB000. But when I try to jump into USB DFU mode, windows prompts the device descriptor but my users The program can use USB to communicate normally. What is the problem?
Sep 30, 2021 11:50 AM UTC
Hello @arilink​,
Please refer to this post and FAQ: DFU mode with system bootloader is not working, while USB does, that may answer your question.
If your question is answered, please select the answer as “Best�? as this will help other users to find answers faster.
Imen
Oct 4, 2021 9:13 AM UTC
Hi @arilink​ ,
Were you able to resolve the issue ? If yes, it will be interesting to share with us your update.
Imen
arilink
arilinkAuthor
Oct 6, 2021 12:57 PM UTC
no i had try the way in your url but it doesn't work DFU is not ok
