SWenn.1
Senior III
September 1, 2024
STM32CubeL4 seems to be missing stm32l4xx.h file?
Hello ...
I cloned the github repo:
https://github.com/STMicroelectronics/STM32CubeL4/tree/master
I am trying to compile the PWR_STOP1_RTC project but keep getting a fatal error
../../../../../../../Drivers/STM32L4xx_HAL_Driver/Inc/stm32l4xx_hal_def.h:29:10: fatal error: stm32l4xx.h: No such file or directory
where can I find this file to include within the ....Drivers/STM32L4xx_HAL_Driver/Inc?
STTwo-32
STTwo-32Best answer
For a succesful clone of this repository. The only way is to use the command
git clone --recursive https://github.com/STMicroelectronics/STM32CubeL4.git
And dont forget the recursive.
Best Regards.
STTwo-32
STTwo-32
Hello @SWenn.1
This file does exist : https://github.com/STMicroelectronics/cmsis_device_l4/tree/a2530753e86dd326a75467d28feb92e2ba7d0df2/Include.
For the clone operation, have you used this command:
If you didn't added the --recursive or you have downloaded directly the repository as. Zip, that will  create a compilation problem.
Best Regards.
STTwo-32
SWenn.1
SWenn.1Author
Senior III
September 1, 2024
I cloned everything but for some reason under the Driver section BSP / STM32L4xx_Nucleo and CMSIS/Device/ST did not come down when I cloned....I had to go up and look into these spaces on github, go to my local area, clone them each separately and then set up the linked files space....
All in all it wasn't very clean as one would hope but I do have things working at this end.
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
