Peter BENSCH
Peter BENSCHBest answer
Jul 21, 2021 9:30 AM UTC
You will find the answer in HAL and the reference manual:
  • Lock and Unlock the FLASH interface using HAL_FLASH_Unlock() and HAL_FLASH_Lock() functions
  • Lock and Unlock the option bytes using HAL_FLASH_OB_Unlock() and HAL_FLASH_OB_Lock() functions
HAL_FLASH_Lock  locks FLASH Registers access using SET_BIT(FLASH->CR, FLASH_CR_LOCK);
HAL_FLASH_OB_Lock locks FLASH Option Byte Registers access using SET_BIT(FLASH->CR, FLASH_CR_OPTLOCK);
Please read the description for the LOCK and OPTLOCK bits in the reference manual under section Flash control register (FLASH_CR).
/Peter
Peter BENSCH
/Peter
