theedge456
May 3, 2014
stm32cube plugin for qtcreator
  • May 3, 2014
  • 901 views
Posted on May 03, 2014 at 13:19
I think I have a problem similar to the one described in the post ''STM32CubeMX as Eclipse plugin on Linux 64 machine''.
As I'm really reluctant to use eclipse, I would like to know if a plugin for Qtcreator is planned ?
Fabien
#stm32cube
stm32cube-t
Posted on May 09, 2014 at 13:47
Hello Fabien,
There is no such support plan so far. I will forward your request.
Thanks for your post.
Mohammad A
Senior
March 31, 2017
Posted on March 31, 2017 at 16:33
Although it's too late to reply, I will just put an answer here for those who may visit this question:
you may easily use QtCreator.
Just generate the code for System Workbench and then put these CMake files in there :
https://github.com/nixmd/STM32CubeMX_cmake
Then run QtCreator and open project and choose CMakeList.txt
That's all.
You can also configure Qtcreator to be used for debugging and running the code. Checkout this page:
http://brightened.ir/post/deploy-stm32-on-qtcreator/
Just don't use the makefile suggested to be used there. Use CMake script mentioned above.
