z1060
STM32Cube CDC new Endpoint
  • October 21, 2014
  • 4 replies
  • 914 views
Posted on October 21, 2014 at 08:53
I creat new USB CDC project and add new IN Endpoint (0x83). I correct USBD_CDC_TransmitPacket for new Endpoint (0x83). Yet data transfer not working.
What should I do
to my IN Endpoint (0x83) worked?
#stm32cube #usb
Montassar BEN ROMDHANE_O
October 21, 2014
Posted on October 21, 2014 at 09:56
Are there any changes that impact the descriptor ? Have you made any modifications on the descriptor ?
With any STM32Cube FW package are you working ?
Regards,
Heisenberg.
z1060
z1060Author
Posted on October 21, 2014 at 10:12
I add new endpoint in descriptor (
function
USBD_CDC_CfgFSDesc) and
initialized
endpoint in USBD_CDC_Init
function
I replaced the CDC_IN_EP for a new IN endpoint (0x83)
in
function
USBD_LL_Transmit (inside USBD_CDC_TransmitPacket).
I use 1.3.0 version FW.
October 21, 2014
Posted on October 21, 2014 at 16:24
Can you provide your usbd_conf.c file, the CDC class modified files, and also your main.c file, to have enough insight into what specifically you are doing, and how.
Regards,
Heisenberg.
z1060
z1060Author
Posted on October 22, 2014 at 07:50
I just
changed the
function
USBD_CDC_TransmitPacket.
uint8_t USBD_CDC_TransmitPacket(USBD_HandleTypeDef *pdev, uint8_t ep_num)
USBD_CDC_HandleTypeDef *hcdc = pdev->pClassData;
if(pdev->pClassData != NULL)
if(hcdc->TxState == 0)
/* Tx Transfer in progress */
hcdc->TxState = 1;
/* Transmit next packet */
USBD_LL_Transmit(pdev,
ep_num,//CDC_IN_EP
hcdc->TxBuffer,
hcdc->TxLength);
// hcdc->TxState = 1;
return USBD_OK;
else
return USBD_BUSY;
else
return USBD_FAIL;
If you call
ep_num
=0x81,
the transmission
operates. If
ep_num=0x82 (or 0x83),
the transmission
does not work
https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/Attachments/1751/files.7z
________________
Attachments :
files.7z : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzSz&d=%2Fa%2F0X0000000bME%2FNADvGkWiUyzgQ6DK4ie.J5L2zqeRPaaff0f3hKx_uoI&asPdf=false
