Matthew1
Feb 21, 2025 5:46 PM UTC
STM32Cube and Azure RTOS hands-on workshop - missing 'STM32-AZURE-RTOS-WS-material.exe' file
The STM32Cube and Azure RTOS hands-on workshop MOOC is missing the example workshop material file. The MOOC link takes one to a single PDF with setup instructions which include a link for "STM32-AZURE-RTOS-WS-Material.exe". This required file is missing from the Google Drive location.
Could you please make the workshop materials available?
1. MOOC page:
2. Google Drive link from above MOOC:
3. Workshop setup PDF with link to materials which takes one back to step (2) above:
Many thanks,
Matthew.
STTwo-32
STTwo-32Best answer
Feb 24, 2025 1:51 PM UTC
Hello @Matthew1
Issue has been solved. The "STM32-AZURE-RTOS-WS-Material.exe" has been added on the LINK on the Slide. Thanks again for escalating this to us.
Best Regards.
STTwo-32
STTwo-32
Feb 21, 2025 8:46 PM UTC
Hello @Matthew1
I will check on this with The concerned team after the weekend and I will get back to you ASAP.
Best Regards.
STTwo-32
Matthew1
Matthew1Author
Feb 24, 2025 10:28 AM UTC
Thanks @STTwo-32 .
STTwo-32
STTwo-32Best answer
Hello @Matthew1
Best Regards.
STTwo-32
Matthew1
Matthew1Author
Feb 24, 2025 3:09 PM UTC
Many thanks for fixing the issue, @STTwo-32 !
Kind regards,
Matthew.
