May 28, 2021 4:55 PM UTC
some improvements
- 1 reply
- 841 views
thanks for the update.
What do i need to exactly enter when terminal asks for "Enter your root CA:"
I entered "Usertrust" or "Tangle" and pressed Enter two times. Program doesnt proceed.
Also new lines on the terminal output dont start from the left since, since you are just using "\n" instead of "\r\n" in the code.
Also writing the code directly in C++ would be much easier to handle and save all the code redundancies and better to integrate into new projects.
Thank you.
Best regards,
Robert
