antonius
Setting on RTOS ?
Posted on March 04, 2017 at 12:21
Everybody,
How can I use SDIO, USB with RTOS ?
I tried initialized RTOS but, SDIO is stopped initializing for some reasons,
Anyone knows ?
Without RTOS, they are working ok.
How to put those functions inside RTOS ?
I tried to understand :
http://www.st.com/content/ccc/resource/technical/document/user_manual/2d/60/ff/15/8c/c9/43/77/DM00105262.pdf/files/DM00105262.pdf/jcr:content/translations/en.DM00105262.pdf
Anyone knows ?
Shall I put test code here :
void MX_FREERTOS_Init(void) {
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* Create the thread(s) */
  /* definition and creation of defaultTask */
  osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128);
  defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
  /* USER CODE BEGIN RTOS_THREADS */
  /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
/* StartDefaultTask function */
void StartDefaultTask(void const * argument)
  /* init code for FATFS */
  MX_FATFS_Init();
  /* init code for USB_DEVICE */
  MX_USB_DEVICE_Init();
  /* USER CODE BEGIN StartDefaultTask */
  /* Infinite loop */
  for(;;)
    osDelay(1);
  /* USER CODE END StartDefaultTask */
/* USER CODE BEGIN Application */
/* USER CODE END Application */
How can I add new task ? and why STM32 suggesting me not using SYSTICK but use TIMER ?
#stm32f1 #sdcard #usb-fs #rtos #sdio
antonius
antoniusAuthor
Posted on March 05, 2017 at 01:05
Is it somewhere here ?
  * File Name          : freertos.c
  * Description        : Code for freertos applications
  * Copyright (c) 2017 STMicroelectronics International N.V.
  * All rights reserved.
  * Redistribution and use in source and binary forms, with or without
  * modification, are permitted, provided that the following conditions are met:
  * 1. Redistribution of source code must retain the above copyright notice,
  *    this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  *    this list of conditions and the following disclaimer in the documentation
  *    and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of other
  *    contributors to this software may be used to endorse or promote products
  *    derived from this software without specific written permission.
  * 4. This software, including modifications and/or derivative works of this
  *    software, must execute solely and exclusively on microcontroller or
  *    microprocessor devices manufactured by or for STMicroelectronics.
  * 5. Redistribution and use of this software other than as permitted under
  *    this license is void and will automatically terminate your rights under
  *    this license.
  * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS 'AS IS'
  * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
  * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
  * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include 'FreeRTOS.h'
#include 'task.h'
#include 'cmsis_os.h'
/* USER CODE END Includes */
/* Variables -----------------------------------------------------------------*/
osThreadId defaultTaskHandle;
/* USER CODE BEGIN Variables */
/* USER CODE END Variables */
/* Function prototypes -------------------------------------------------------*/
void StartDefaultTask(void const * argument);
extern void MX_FATFS_Init(void);
extern void MX_USB_DEVICE_Init(void);
void MX_FREERTOS_Init(void); /* (MISRA C 2004 rule 8.1) */
/* USER CODE BEGIN FunctionPrototypes */
/* USER CODE END FunctionPrototypes */
/* Hook prototypes */
/* Init FreeRTOS */
  MX_FATFS_Init();
  /* Infinite loop */
  for(;;)
    osDelay(1);
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Rob.Riggs
Senior
March 5, 2017
Posted on March 05, 2017 at 03:35
I would start by increasing the stack size in your
osThreadDef to 512 (or higher) and see if that makes a difference.  Invariably I have to increase the stack size in the default task when using USB CDC.
I use GCC as my compiler. When I'm in doubt about whether this is a problem, I have GCC dump stack usage statistics (-fstack-usage) for analysis.
Stack usage is what trips me up most when doing RTOS programming.
antonius
antoniusAuthor
Posted on March 24, 2017 at 23:55
Does it matter with init code if it's outside RTOS ?
Or have conflict between SDIO interrupt and RTOS interrupt ?
