NMALH
Jul 15, 2021 4:49 AM UTC
server-side knowledge of disconnection of the client without getting close command from the client .
Amel NASRI
Jul 15, 2021 10:07 AM UTC
Hello @NMALH​ ,
To be able to provide you required help, could you please provide some more details on your request?
-Amel
NMALH
NMALHAuthor
Jul 16, 2021 4:52 AM UTC
We are connecting multiple clients with a single server. When the client sends a close connection command we are able to detect it on the server side, whereas when the client gets disconnected by any other means i.e. when the client is powered off or the ethernet cable is damaged then we are not able to identify whether that particular client is still connected or not. We are using LWIP library for creating client and server.
waclawek.jan
Jul 16, 2021 5:28 AM UTC
Have a look at TCP keepalive, and its options in lwip.
