Seeking USB Host (Mass Storage Class) Example for NUCLEO-N657X0-Q (STM32N6)
I am working with the NUCLEO-N657X0-Q and I am looking for a reference project or a pointer to an example that implements USB Host Mass Storage Class (MSC).
My Goal: I need to mount a USB memory stick to read test vectors, process them using the Cortex-M55, and then write the output results back to the USB stick.
Current Blockers:
I have searched through the latest STM32CubeN6 Firmware Package, but I haven't found a ready-to-use USB Host MSC example specifically tailored for this Nucleo board.
Given the new architecture of the STM32N6 (including the high-speed USB PHY and the NPU/M55 pipeline), I want to ensure I am using the correct driver implementation for the USB stack.
Does anyone have a pointer to a compatible example or a known working configuration for USB Host on the N6 series? Specifically, I'm looking for guidance on integrating ThreadX/USBX (or the classic middleware) with FileX/FatFs for this board.
Any help or GitHub links would be greatly appreciated!
T_Hamdi
T_HamdiBest answer
Hello @DonutFace
Welcome to the ST community,and thank you for your interest!
For the USB host (mass storage class) application, refer to the example available for the STM32N6570-DK board. You can adapt this example for the Nucleo board.
You can find the example here on GitHub: STM32CubeN6 -- Ux_Host_MSC example
Thank you
hamdi
"To give better visibility on the answered topics, please click on ""Accept as Solution"" on the reply which solved your issue or answered your question.Hamdi Teyeb"
T_Hamdi
T_HamdiBest answer
Hello @DonutFace
Thank you
hamdi
