Pavel_47
Jun 3, 2023 6:36 PM UTC
Search for a solution on encoding audio in S/PDIF
I'm looking for a simplest solution for encoding 1 channel audio.
Ideally at input - signal from microphone, ADC - not necessary high-end (10...12bit sufficient), output - S/PDIF. Does exist an IC that integrates whole this stuff ?
Thanks.
LCE
Principal III
Jun 21, 2023 9:18 AM UTC
Almost every STM32 with a SAI (serial audio interface) has an incorporated SPDIF transmitter.
So you can use on SAI block to connect the ADC, the other block for SPDIF output.
I'm using that all the time (G4, F7, H7), works reliable.
