Tee
Nov 4, 2021 8:08 AM UTC
SD Card not mounted and returns FR_DISK_ERR when put in a FREERTOS task.
I am using STM32H7, FatFS, FreeRTOS to write/read from an SD Card (SDMMC), it was working fine before I implemented FreeRTOS but after I did , it started returning this error when mounting the SD Card.
Attached is my code and initialization related to the SD Card.
Walid ZRELLI
Jan 14, 2022 2:08 PM UTC
Hello @Tee​ ,
You can refer to the following example provided under our H7 Firmware Package:
  • Projects\STM32H743I-EVAL\Applications\FatFs\FatFs_uSD_DMA_RTOS
This might help you.
BeST Regards,
Walid
