PChia.2237
Senior
Mar 2, 2022 11:06 AM UTC
RTOS multiple uart
there is some solution for sending data over multiple uarts with RTOS,
because HAL_UART_Transmit,HAL_UART_Transmit_IT,HAL_UART_Transmit_DMA not send data in second uart. Still BUSY.
Thank you in advantages
Mar 2, 2022 2:14 PM UTC
If it returns HAL_BUSY, the peripheral is still servicing the previous call. You will need to wait or implement a buffer to hold data until the peripheral is ready to send it out again.
