phlf
RTC - [STM32CubeL4][1.13.0][stm32l4xx_hal_rtc_ex] Missing EXTI interrupt activation
  • December 6, 2018
  • 0 replies
  • 602 views
Problem:
RTC Wakeup interrupt is not working on STM32L4 after calling the HAL_RTCEx_SetWakeUpTimer_IT.
Cause:
A preprocessor macro check rules out a call to the __HAL_RTC_WAKEUP_EXTI_ENABLE_IT for uC other than STM32L412xx / STM32L422xx in the file stm32l4xx_hal_rtc_ex.c
Fix:
Add a call to __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_IT just before __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_EVENT line 912:
#if defined(STM32L412xx) || defined(STM32L422xx)
 /* In case of WUT autoclr, the IRQ handler should not be called */
 if (WakeUpAutoClr != 0u)
 /* RTC WakeUpTimer EXTI Configuration: Event configuration */
 __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_EVENT();
 else
 /* RTC WakeUpTimer EXTI Configuration: Interrupt configuration */
 __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_IT();
#else /* defined(STM32L412xx) || defined(STM32L422xx) */
#endif /* defined(STM32L412xx) || defined(STM32L422xx) */
becomes:
 else
