Jun 22, 2026 09:00 UTC
RTC hours keep counting after 24 hours
I am using a STM32G474 and the RTC is counting >24.
I have setup the RTC with the STM32CubeMX.
regards Mark,
waclawek.jan
waclawek.janBest answer
Jun 22, 2026 09:41 UTC
Most probably the usual case of inadvertently set AM/PM mode, and that usually happens through using uninitialized structs when setting time.
mƎALLEm
Jun 22, 2026 09:05 UTC
Hello ​@MdeJong and welcome to the ST community,
You need to provide more details: your code and your ioc file so others could help you efficiently.
Good luck.
Andrew Neil
Jun 22, 2026 09:34 UTC
Welcome to the forum
As ​@mƎALLEm said, you need to give more details - Please see How to write your question to maximize your chances to find a solution.
But first, check your initialisations - see:
waclawek.jan
MdeJongAuthor
Jun 25, 2026 13:03 UTC
many thanks, that gave me the right direction to look for.
regards Mark,
Jun 22, 2026 13:30 UTC
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
MdeJongAuthor
Jun 25, 2026 13:22 UTC
I have found the cause.
in the function HAL_StatusTypeDef HAL_RTC_Init(RTC_HandleTypeDef *hrtc):
When the INITS bit in the ICSR register is set, then the CR register is not initialized.
This means that when the year is != 0 the register CR will not be set, also not the FMT bit,
So you can not switch between 12 and 24 hours mode when the year is != 0.
Regards Mark,
