TDKBest answer
Oct 6, 2020 1:35 PM UTC
It sounds like you got a reasonable response already on Github. There is not a bug, the convention of not right-shifting values is prevalent throughout HAL. You're requesting a change that would break backwards compatibility with limited upside. If I was coding HAL, I would have given the same response.
TDKBest answer
