reliability of OTG USB on stm32f4 Disco
Posted on September 07, 2015 at 09:51
I am intending to port GRBL Gcode interpreter to run on stm32f4 discovery and I have seen several reports that the OTG USB port ( more specifically the provided ST firmware ) is not reliable.
A colleague in the UK working with audio synth could not get reliable data transfer and moved to using USART where it worked as designed. A partial port of GRBL to STM32 found similar reliability issues and adopted a similar solution. Is this a known issue, is this the right place to raise it ? Thanks. #stm32f4-discovery-otg-usb
