May 17, 2025 1:31 PM UTC
Record audio using PDM OR DFSDM
I am working with STM32H757I-EVAL. The task is to record audio, store it in SD Card. Since, STM32H757I-EVAL has PDM Data format as well as DFSDM data format which would be better to interface with or is there anyother data format that can be used?
AScha.3
May 17, 2025 5:05 PM UTC
depends, where your data is coming from .
If from mic , with pdm pulse stream, you have to convert to PCM , to get something like a wav file.
You could use the DFSDM module for this, or (from audio lib) pdm->pcm conversion/downsampling .
