Sep 24, 2021 7:36 PM UTC
Problems with FatFS and FreeRTOS integration
Hi, everyone.
I have a board with STM32F215 uC and I want to create a Data Logger on FreeRTOS.
I've been reading about these problems and I don't find what's going on.
I modified the task's stack on the FR configuration, I made sure that timebase source it's different from systick. I use a Mutex on the SD_task, but nothing works... I'm wondering if someone here can provide me any simple example. I'm desperate.
Peripheral for SD is SPI.
Thanks a lot for any flash of illumination.
Sorry for my bad english.
Best answer
Nov 9, 2021 7:58 PM UTC
Thank you, the issue was on STACK_DEPTH of the Task. I set it with 512 Bytes and works fine.
Walid ZRELLI
Sep 27, 2021 1:29 PM UTC
Hello @Araceli.Guerrero​ ,
Check the following example provided under our F2 Firmware package ( Path: Projects\STM322xG_EVAL\Applications\FatFs\FatFs_uSD_RTOS )
I hope this help you.
BeST Regards,
Walid
Best answer
