Feb 21, 2025 6:10 PM UTC
POSIX support in FreeRTOS on STM32
As far as I know,
STM32 does not support the POSIX abstraction layer for FreeRTOS.
That means I can not use functions like:
  • Interact with tasks through: 'pthread_create', 'pthread_join'..
  • Use POSIX glue elements like: 'pthread_mutex'...
  • Etc
If I am porting a big FreeRTOS project that is using POSIX to STM32:  what I need to do? Is there a way of achieving it painlessly?
Thanks,
Carles
mƎALLEm
mƎALLEmBest answer
Feb 21, 2025 6:15 PM UTC
I don't think POSIX-FreeRTOS is supported natively by STM32 but I think you need to do it yourself. See https://www.freertos.org/Documentation/03-Libraries/05-FreeRTOS-labs/03-FreeRTOS-plus-POSIX/00-FreeRTOS-Plus-POSIX
https://github.com/FreeRTOS/Lab-Project-FreeRTOS-POSIX
mƎALLEm
mƎALLEmBest answer
Feb 22, 2025 5:40 PM UTC
Thanls @mƎALLEm ,
I will try to use this FreeRTOS Lab Project and will see if it works (and then I will set it as 'Accept as Solution'.
Many thanks!
