STTwo-32
STTwo-32Best answer
Jun 12, 2024 6:02 PM UTC
Hello @DarthNecro95
I suggest you follow the recommendations of the AN3364 and AN4904 for an easy migration between STM32F1 and STM32F4.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @DarthNecro95
Best Regards.
STTwo-32
Jun 12, 2024 6:09 PM UTC
Pin mapping might be easier, but then other high pin count peripherals tend to only provide singular choices.
I'd make a new donor project, getting diagnostic, debug and output working, and then start merging in portions, starting with the simplest, typically GPIO's and then moving to more complex as you can build and test
