Sep 15, 2025 12:13 PM UTC
peak current mode control
im trying to implement peak current mode contorl using stm32G474
i have a question about PCMC. in PCMC, if the sensed voltage from Current trasnformer does not reach to target value, does the switch remain  continuously on, or does it turn off according to the original switching frequency?
if neither is the case, does it turn off for a very short moment that matches the switching frequency and then turn on again to chasing target voltage? (==> duty ratio nearly 0.99)
thank you for infomation
Sep 17, 2025 8:33 AM UTC
Hello @김남제,
I recommend checking out this post: DAC Sawtooth waveform generation for peak current mode boost converter
I hope my answer has helped you. When your question is answered, please select this topic as the solution that answered you, as it will help others find that answer faster.
Thanks for your contribution.
Dor_RH
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Dor_RH
