Apr 13, 2026 13:30 UTC
NUCLEO-H753ZI board and want to set up Ethernet RMII communication using LWIP
Hi Everyone,
I am working on a NUCLEO-H753ZI board and want to set up Ethernet RMII communication using LwIP in STM32CubeIDE.
I am looking for step-by-step guidance from the IOC file configuration to the generated code, including:
Pinout configuration for RMII.
LwIP middleware settings.
MPU region configuration for Ethernet and LwIP memory
Generating code and linker settings
 Any tips to ensure that ping from PC works reliably
Could provide a complete, detailed guide. how to configure CubeIDE and LwIP for NUCLEO-H753ZI.
Thanks in advance.
Apr 13, 2026 16:29 UTC
Hello @Raja_Reddy, and Welcome to ST Community!
Attached is an example project. You can inspect the configuration and build on it. Let me know if you need further assistance.
Best regards,
To improve visibility of answered topics, please click 'Accept as Solution' on the reply that resolved your issue or answered your question.
MOBEJ
Apr 14, 2026 08:40 UTC
Hello @Raja_Reddy  ,
You may find the following resources helpful:
You can also check the STM32H7 Ethernet examples available here:
Br
