FTEHR.1
Jun 10, 2021 10:20 AM UTC
noisy audio recording after averaging data
I am using F446 board with CCA02m2.
when I just send the audio to USB output, I can record data in audacity. But if I do simple processing such as averaging data, the output is high clipped data.
I checked the data range and overflowing. there is no problem in this case.
Is there any advice here?
waclawek.jan
Jun 10, 2021 1:48 PM UTC
Yes. Recheck the data range and overflowing.
Instead of using real audio source, try some artifical data e.g. sawtooth.
