May 14, 2025 8:51 AM UTC
MCU jumps to wrong address after flashing due to incorrect vector table configuration.
Hi, after flashing the MCU, it jumps to an incorrect system memory address instead of my application code. I looked into the issue and found that the vector table isn't properly set in flash. I'm trying to understand how to set it correctly, but I'm still not getting it.
May 14, 2025 9:59 AM UTC
Hello @Kartik_Shetti
Could you please check the state boot0 pin?
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
