AKons
September 14, 2019
MCU freezes when starting ADC in DMA mode
  • September 14, 2019
  • 0 replies
  • 686 views
i want to start an ADC in DMA Mode, but everytime i run HAL_ADC_Start_DMA the MCU stops.
Here is the section of my code where it happens:
if(newpwmperiod == 1 && adc_dma_status == 0){
 HAL_UART_Transmit(&huart2, test, 4, HAL_MAX_DELAY);
	HAL_ADC_Start_DMA(&hadc1, (uint32_t*)adc_signal, cos_pointsperperiod);
	adc_dma_status = 1;
The first HAL_UART_Transmit works, but the second after the HAL_ADC_Start_DMA doesn't.
here are my configurations generated by mxcube:
 * File Name : ADC.c
 * Description : This file provides code for the configuration
 * of the ADC instances.
 * @attention
 * <h2><center>&copy; Copyright (c) 2019 STMicroelectronics.
 * All rights reserved.</center></h2>
 * This software component is licensed by ST under BSD 3-Clause license,
 * the "License"; You may not use this file except in compliance with the
 * License. You may obtain a copy of the License at:
 * opensource.org/licenses/BSD-3-Clause
#include "adc.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
/* ADC1 init function */
void MX_ADC1_Init(void)
 ADC_ChannelConfTypeDef sConfig = {0};
 /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
 hadc1.Instance = ADC1;
 hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
 hadc1.Init.Resolution = ADC_RESOLUTION_12B;
 hadc1.Init.ScanConvMode = DISABLE;
 hadc1.Init.ContinuousConvMode = DISABLE;
 hadc1.Init.DiscontinuousConvMode = DISABLE;
 hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
 hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T2_TRGO;
 hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc1.Init.NbrOfConversion = 1;
 hadc1.Init.DMAContinuousRequests = DISABLE;
 hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 if (HAL_ADC_Init(&hadc1) != HAL_OK)
 Error_Handler();
 /** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
 sConfig.Channel = ADC_CHANNEL_1;
 sConfig.Rank = 1;
 sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
 if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
 Error_Handler();
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
 if(adcHandle->Instance==ADC1)
 /* USER CODE BEGIN ADC1_MspInit 0 */
 /* USER CODE END ADC1_MspInit 0 */
 /* ADC1 clock enable */
 __HAL_RCC_ADC1_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 /**ADC1 GPIO Configuration
 PA1 ------> ADC1_IN1
 GPIO_InitStruct.Pin = GPIO_PIN_1;
 GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
 /* ADC1 DMA Init */
 /* ADC1 Init */
 hdma_adc1.Instance = DMA2_Stream0;
 hdma_adc1.Init.Channel = DMA_CHANNEL_0;
 hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
 hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
 hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
 hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
 hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
 hdma_adc1.Init.Mode = DMA_NORMAL;
 hdma_adc1.Init.Priority = DMA_PRIORITY_LOW;
 hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
 if (HAL_DMA_Init(&hdma_adc1) != HAL_OK)
 Error_Handler();
 __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1);
 /* USER CODE BEGIN ADC1_MspInit 1 */
 /* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
 /* USER CODE BEGIN ADC1_MspDeInit 0 */
 /* USER CODE END ADC1_MspDeInit 0 */
 /* Peripheral clock disable */
 __HAL_RCC_ADC1_CLK_DISABLE();
 HAL_GPIO_DeInit(GPIOA, GPIO_PIN_1);
 /* ADC1 DMA DeInit */
 HAL_DMA_DeInit(adcHandle->DMA_Handle);
 /* USER CODE BEGIN ADC1_MspDeInit 1 */
 /* USER CODE END ADC1_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
 * File Name : TIM.c
 * of the TIM instances.
 * @attention
#include "tim.h"
TIM_HandleTypeDef htim2;
DMA_HandleTypeDef hdma_tim2_ch1;
/* TIM2 init function */
void MX_TIM2_Init(void)
 TIM_ClockConfigTypeDef sClockSourceConfig = {0};
 TIM_MasterConfigTypeDef sMasterConfig = {0};
 TIM_OC_InitTypeDef sConfigOC = {0};
 htim2.Instance = TIM2;
 htim2.Init.Prescaler = 0;
 htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim2.Init.Period = 512-1;
 htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
 htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
 Error_Handler();
 sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
 if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
 Error_Handler();
 if (HAL_TIM_PWM_Init(&htim2) != HAL_OK)
 Error_Handler();
 sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;
 sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
 if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
 Error_Handler();
 sConfigOC.OCMode = TIM_OCMODE_PWM1;
 sConfigOC.Pulse = 0;
 sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
 sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
 if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
 Error_Handler();
 HAL_TIM_MspPostInit(&htim2);
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* tim_baseHandle)
 if(tim_baseHandle->Instance==TIM2)
 /* USER CODE BEGIN TIM2_MspInit 0 */
 /* USER CODE END TIM2_MspInit 0 */
 /* TIM2 clock enable */
 __HAL_RCC_TIM2_CLK_ENABLE();
 /* TIM2 DMA Init */
 /* TIM2_CH1 Init */
 hdma_tim2_ch1.Instance = DMA1_Stream5;
 hdma_tim2_ch1.Init.Channel = DMA_CHANNEL_3;
 hdma_tim2_ch1.Init.Direction = DMA_MEMORY_TO_PERIPH;
 hdma_tim2_ch1.Init.PeriphInc = DMA_PINC_DISABLE;
 hdma_tim2_ch1.Init.MemInc = DMA_MINC_ENABLE;
 hdma_tim2_ch1.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
 hdma_tim2_ch1.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
 hdma_tim2_ch1.Init.Mode = DMA_CIRCULAR;
 hdma_tim2_ch1.Init.Priority = DMA_PRIORITY_LOW;
 hdma_tim2_ch1.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
 if (HAL_DMA_Init(&hdma_tim2_ch1) != HAL_OK)
 Error_Handler();
 __HAL_LINKDMA(tim_baseHandle,hdma[TIM_DMA_ID_CC1],hdma_tim2_ch1);
 /* USER CODE BEGIN TIM2_MspInit 1 */
 /* USER CODE END TIM2_MspInit 1 */
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* timHandle)
 if(timHandle->Instance==TIM2)
 /* USER CODE BEGIN TIM2_MspPostInit 0 */
 /* USER CODE END TIM2_MspPostInit 0 */
 /**TIM2 GPIO Configuration
 PA0-WKUP ------> TIM2_CH1
 GPIO_InitStruct.Pin = GPIO_PIN_0;
 GPIO_InitStruct.Alternate = GPIO_AF1_TIM2;
 /* USER CODE BEGIN TIM2_MspPostInit 1 */
 /* USER CODE END TIM2_MspPostInit 1 */
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* tim_baseHandle)
 /* USER CODE BEGIN TIM2_MspDeInit 0 */
 /* USER CODE END TIM2_MspDeInit 0 */
 __HAL_RCC_TIM2_CLK_DISABLE();
 /* TIM2 DMA DeInit */
 HAL_DMA_DeInit(tim_baseHandle->hdma[TIM_DMA_ID_CC1]);
 /* USER CODE BEGIN TIM2_MspDeInit 1 */
 /* USER CODE END TIM2_MspDeInit 1 */
I hope you can help me.
