Apr 20, 2026 13:44 UTC
Master DALI-2 with STM32F7
Hi all,
I'm looking for a free library or source C code to develop and application for DALI master manager with STM32F7 board.
I didn't find anything ....
Any suggestion?
Many thanks
Fabio
Peter BENSCH
Peter BENSCHBest answer
Apr 20, 2026 14:11 UTC
The question of open source for DALI and DALI-2 comes up from time to time in the community. Apart from very old DALI examples for STM32F1 and STM32L1, there were no further libraries.
However, one of our partners in our Partner Program has since developed solutions that can be licensed from them - but of course, this is not open source: MBS Solutions - DALI Stack (ST partner).
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Apr 20, 2026 14:23 UTC
Thanks Peter,
you are speaking about this?
https://github.com/tomyqg?tab=repositories&q=dali&type=&language=&sort=
I saw that projects ... I'm new about DALI and I didn't understand how is possible to work as master.
It seems the application runs based on the receive DALI request
Have you ever used that example?
Fabio
Peter BENSCH
Apr 20, 2026 14:39 UTC
No, I was talking about the DALI-2 stack from MBS. I’m afraid you won’t find anything even remotely useful in the open source field for DALI-2, because systems using DALI-2 have to be certified by the DALI Alliance.
Good luck!
/Peter
Apr 20, 2026 14:41 UTC
ok,
many thanks Peter.
Fabio
May 13, 2026 06:53 UTC
Hello all,
I reopen this topic just to know if is there anyone used the MBS DALI library or is there any application examples using their API.
Just to have  look
Fabio
Andrew Neil
May 13, 2026 08:44 UTC
@ilcontefabio wrote:
MBS DALI library
You mean this: https://en.mbs-solutions.de/dali-stack ?
You should ask MBS that!
See also: https://www.mbs-support.de/
They offer a Demo:
https://en.mbs-solutions.de/service-by-mbs
https://en.mbs-solutions.de/kontakt
May 13, 2026 09:02 UTC
thank Andrew
you are completely right but I asked just to have an idea about the estimates for using that library from
someone have already used
Thanks Fabio
Ozone
Principal
May 13, 2026 08:52 UTC
I would drop the STM32F7 or even STM32 criterium, and look for any MCU-based implementation.
There are very few MCUs that support even biphase serial protocol modes out of the box, so you have to adapt the HAL layer anyway.
NXP had a DALI implementation and specific eval boards several years ago, not sure if they are abandoned in the meantime.
Andrew Neil
A quick Google* search came up with:
https://www.nxp.com/docs/en/fact-sheet/DALIREFDESIGN.pdf
https://www.nxp.com/docs/en/supporting-information/RMACSDALIREF.pdf
https://www.design-reuse.com/news/202521945-nxp-brings-arm-cortex-m0-to-dali-and-dmx512-lighting-control-systems/
- is that what you were thinking of?
As @Peter BENSCH suggested, it looks like this isjust DALI - not DALI-2 ?
* Other internet search engines are available
