ABasi.2
Senior
Nov 27, 2024 2:31 PM UTC
Looking for PVD example with STM32G0
hello!
i have a question about the power voltage detector in (external input analog voltage)
i have a adjustable power supply connected on the pin (using a nucleo-G0B1RE)
i was thinking that if i drop the voltage on the pin under the vref int voltage a interrupt should be triggered.. but unfurtunately i'm not able to do that..
there is an exmple? i 'm able to use the internal  analog voltage without problem
thank you
Amel NASRI
Nov 29, 2024 2:15 PM UTC
Amel NASRI
Nov 29, 2024 2:23 PM UTC
Hi @ABasi.2 ,
Please try using this example: Github: STM32CubeG0/Projects/NUCLEO-G0B1RE/Examples/PWR/PWR_PVD.
Refer to the readme file to understand how it works and to know more about the required hardware setup to test the example properly.
-Amel
