Issue with the USB mass storage device class
We are using STM32L4R5 micro-controller, external NOR flash as a storage media and ST USB device library.
We are getting the pop-up as "The last USB device you connected to this computer malfunctioned" on windows 10 system when directly remove the USB device and reconnect it to the system.
But next time when re-start the device, USB drive detected properly and again showing same pop-up, after disconnect of the USB drive and reconnect it to the windows system.
Is there any eject sequence required or need to follow any other sequence?
Kindly share the solution for same.
