Issue with MX_JPEG_Init Blocking on STM32N6DK750
I’m trying to add the JPEG encoder to be able to save images in JPEG format to the SD card.
While debugging with LEDs, I noticed that MX_JPEG_Init blocks the program, whereas HPDMA is working correctly.
I have added all the necessary files for JPEG, but it doesn’t seem to activate.
Interestingly, when I disable MX_JPEG_Init, I can see the images on the screen connected to the board without any issue.
I’m wondering if there is a configuration problem with the JPEG or if I’m missing something.
For reference, I’m using the STM32N6 Discovery Kit (STM32N6DK750).
Thanks for any advice!
Hi @HMTb
Do you reproduce using the provided firmware here?
HMTbAuthor
Hi, yes, I cloned the repository with all submodules recursively to make sure nothing was missing. Then I started modifying the DCMIPP snapshot project to add JPEG support.
@HMTb  I would suggest to test the example JPEG_EncodingFromOSPI_DMA as it is and see if the issue persists.
