Issue with bare metal LWIP/Wolfssl on stm32n6570-dk / can not start Handshake
I get two errors from here:
ret = wolfSSL_connect(g_tls.ssl);
if (ret == WOLFSSL_SUCCESS) {
printf("TLS handshake OK\r\n");
g_tls.state = TLS_STATE_TLS_ESTABLISHED;
} else
int err = wolfSSL_get_error(g_tls.ssl, ret);
if (err == WOLFSSL_ERROR_WANT_READ ||
err == WOLFSSL_ERROR_WANT_WRITE) {
} else {
printf("TLS handshake failed: %d\r\n", err);
g_tls.state = TLS_STATE_ERROR;
ret = -1 and err = 32
No ClientHello is being sent.
This is how the main looks:
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "lwip/opt.h"
#include "lwip/init.h"
#include "netif/etharp.h"
#include "lwip/netif.h"
#include "lwip/timeouts.h"
#if LWIP_DHCP
#include "lwip/dhcp.h"
#endif
#include "ethernetif.h"
#include "main.h"
#include "app_ethernet.h"
//#include "tcp_echoserver.h"
#include "tls_client.h"
#if defined(__ICCARM__)
#include <LowLevelIOInterface.h>
#endif /* __ICCARM__ */
/* USER CODE END Includes */
/* New definition from EWARM V9, compatible with EWARM8 */
int iar_fputc(int ch);
#define PUTCHAR_PROTOTYPE int iar_fputc(int ch)
#elif defined(__ARMCC_VERSION)
/* ARM Compiler 6*/
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#elif defined(__GNUC__)
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
struct netif gnetif;
UART_HandleTypeDef UartHandle;
RNG_HandleTypeDef hrng;
static void SystemClock_Config(void);
static void BSP_Config(void);
static void Netif_Config(void);
static void MX_USART1_UART_Init(void);
static void RISAF_Config(void);
static void MPU_Config(void);
static void MX_RNG_Init(void);
* @brief The application entry point.
* @retval int
int main(void) {
/* Configure the MPU */
MPU_Config();
/* Enable the CPU Cache */
/* Enable I-Cache---------------------------------------------------------*/
SCB_EnableICache();
/* Enable D-Cache---------------------------------------------------------*/
SCB_EnableDCache();
HAL_Init();
SystemClock_Config();
RISAF_Config();
MX_USART1_UART_Init();
/* Configure the LEDs ...*/
BSP_Config();
printf("TLS 1.3 Handshake \r\n");
printf("STM32N6570 board \r\n");
printf("State: Ethernet Initialization ... \r\n");
/* Initialize the LwIP stack */
lwip_init();
/* Configure the Network interface */
Netif_Config();
/* UDP client connect */
// tcp_echoserver_init();
TLS_GlobalInit();
/* Infinite loop */
ip_addr_t serverIp;
IP4_ADDR(&serverIp, 192,168,50,1);
// TLS_ClientStart(&serverIp, 443);
static int started = 0;
while (1)
ethernetif_input(&gnetif);
sys_check_timeouts();
#if LWIP_NETIF_LINK_CALLBACK
Ethernet_Link_Periodic_Handle(&gnetif);
#endif
#if LWIP_DHCP
DHCP_Periodic_Handle(&gnetif);
#endif
if (!started &&
netif_is_up(&gnetif) &&
!ip4_addr_isany_val(*netif_ip4_addr(&gnetif))) {
started = 1;
printf("IP: %s\r\n", ip4addr_ntoa(netif_ip4_addr(&gnetif)));
printf("NM: %s\r\n", ip4addr_ntoa(netif_ip4_netmask(&gnetif)));
printf("GW: %s\r\n", ip4addr_ntoa(netif_ip4_gw(&gnetif)));
ip_addr_t serverIp;
TLS_ClientStart(&serverIp, 11111); // besser: Port auf dem dein wolfSSL server wirklich lauscht
TLS_ClientProcess();
I used this as base:
https://github.com/ABESTM/stm32n6-classic-coremw-apps/tree/main/Projects/STM32N6570-DK/Applications/LwIP/LwIP_TCP_Echo_Server
I had to make modifications to the linker script, as it was only limited to the fsbl RAM.
3mika3Author
The TCP Handshake works, so it is connected to the server, but like I wrote, it is not starting the TLS Handshake.
