Nov 11, 2023 12:01 AM UTC
Issue using osThreadFlagsWait() function
Trying to use osThreadFlagsWait() in my command handler for command processing thread to save CPU utilization and seeing issue where system gets stall.
while (1) {
  int cnt = getcmd();
  if (cnt >= 0) {
    process_command();
  } else {
    osThreadFlagsWait(0, osFlagsWaitAny, DELAY_TASK_10MS_TICKS);
without using osThreadFlagsWait() command line processing is ok, when osThreadFlagsWait() used to save CPU utilization system gets stalled.
@Tesla DeLorean
I was wondering if there is anything special which needed to be taken care while using this function.
Thanks in advance for your support!
