Haithem Rahmani
Hi @one V​,
for MX_AZRTOS_Init() & MX_AZRTOS_Process() you'll need to unselect the "Generate Code" check box. If you don't want to generate them.
regards
Haithem.
one V
one VAuthor
Are you sure? I tried but it didn't work.
Khouloud ZEMMELI
Hello @one V​
Thank you for raising this issue to our attention, the Do not generate Function Call problem was detected with all packs.
I have reproduce it, sorry for any inconvenience this may have caused, issue will be fixed.
Khouloud
